100 mbps speed limit on Excitel LAN
Gurugram
Excitel, TriplePlay
I have 300 mbps plan on Excitel and got the 2000 security deposit ONT which is the GX (Genexis) EARTH 4222 which claims to have 4 GE (Gigabit Ethernet) ports according to their manual. Upon connecting LAN with my laptop which has a Qualcomm Atheros AR8171/8175 PCI-E Gigabit Ethernet Controller (NDIS 6.30), the speed is limited to 100 mbps. I have tried changing the Speed & Duplex setting in the adapter options but there's no option for 1 gbps in there. I have also tried uninstalling and updating the LAN drivers, still no luck. I am also using a CAT 7 cable so that eliminates the possibility of the cable being a bottleneck. Anyone else facing the same problem?
Have you tried connecting on all 4 ports of the ONT one by one and check that all are giving lower speeds?
