3 Digit Universal Remote Control Code for tata sky dth
  • Thread starter Thread starter shantam2005
  • Replies Replies 5
  • Views Views 23,319
shantam2005
IrRegulars
Maha Mediacom
Hello guys, I have just got an LG Jazz TV .I want to use its remote to control my Tata Sky also but I couldnt find the appropriate 3 Digit code for it:huh:.If anyone of you has the code for the Humax STB please tell me.
Controlling STB by TV remote is possible? I know reverse is possible, and I am using it (for SKY UK's STB remote to control TV Audio volume).Try searching for SKY UK's code, you may find some codes, but I am not sure if SKY uses Humax STB. You can also search for Humax STB codes.
yes if its a programmable remote control. if ur TV/STB codes are already pre-set in remote then all u need is code related to ur STB. Otherwise u can manual program the remote control which cud be a bit tough but not very tough.
Dear Shantam....I have a universal remote... which has been configured to my Tata Sky STB... But i used a 4 digit code to configure it... it was 1997:thumb:
