5G speed throttling on Cloudflare WARP
  • Thread starter Thread starter naitik1203
  • Replies Replies 4
  • Views Views 94
Lucknow
Jio
RJIL 5G is now starting to cap your speeds on cloudflare warp to max 100Mbps like it was Airfiber or shit.
I tried using Cloudflare one client on windows tried using different modes like WARP Proxy, WARP, WARP WITH DOH, WARP WITH DOT, TUNNEL ONLY
My warp tunnel protocol says MASQUE still speeds are capped but when turned off warp speeds go upto 300~350 Mbps (day time).
Any help to fix this will be appreciated.
Earlier scenario was opposite jio throttled connection without warp and with warp speeds reached max possible (300~320Mbps in day time)
@goku35 I believe so too.
Jio DPI has gone aggressive too much nowadays on 5G making internet slow and hence airplane mode has to turned on and off every 30mins making user experience shit.
Cloudflare warp was solution to this now they have throttled it too.
Piece of Rats!!
Throttling is done to keep speeds at 50% of the current max on 5G without any VPN.
This means if you are getting 500Mbps on normal 5G no vpn then you will get max 250Mbps on 5G with vpn
What a shit capping can't they remove DPI or atleast not throttle Cloudflare WARP, cloudflare has a nice routing which is way better than Jio
