900+ plan(256 kbps) speed...only 30 kbps
  • Thread starter Thread starter mytime545
  • Replies Replies 4
  • Views Views 6,019
mytime545
home 250
Hey friends...i have 900+ plan...dataone in vadodara.........i got only 30 kbps speed???? is it ok....can any one tell me What speed should come...plz help me out.....
The maximum speed BSNL provides for UL home plans is 256kbps. So u should be getting a maximum of 32kBps. So dont worry, u are getting the rated speeds according to your plan.
kbps = kilo bits per second
kBps = kilo bytes per second
1 Byte = 8 bits.
so, 1 kBps = 8 kbps. And thats why the calculation suggested by cool_techie_vm: 32 kBps = 32 * 8 kbps which is 256 kbps.
Your windows download displays the speed in kB / Sec which is kBps
