@Yeskaye box reboots frequently with any apparent reason in the midst of a running program. I am forced to start from home all over agai
The Reboot problem in your router is due to the insufficient RAM to the Apps you are using
This happens when you load high end apps on a low end machine
Second...when you run Graphic intensive apps like Games and Graphic apps
I think in your case ....when you are running a low end machine . The issue is , it already has bloatware preinstalled by Jio company
On top of that if we install our required apps ....it becomes a mess
This may be a Hardware problem too....but 9 out of 10 times its a RAM problem
