Thanks for the replies, here's the answers for your questions.
Essbebe
Do you have a PHone extension Port here ?
NO
Did you install the Drivers etc in Desktop using the cd supplied. ?
Yes. The drivers are installed properly and
windows cannot see any issues on that.
Mention OS in use. The SSID, which appears in
Laptop should show in WLAN in Desktop.
Windows 7 Ultimate, SSID shows in laptop. but not in desktop with wireless adapter.
Am I using right adapter? I purchased
Belkin N300 also, but with no luck.
What is the distance between the rooms ? ( obstructions ?/walls/??)
6 meters. Laptop connects from that area. Shows 4 bars out of 5.
Where you have to keep the wifi
router ? Room1 desktop room
Room1, New desktop is in another room.
Tested the adapter in laptop without any luck. The adapter is
D-Link N150 (DWA-125).
Am I using right adapter? Or else what should I do?
Please help.. Thanks
Any erro you're getting or is it simply not connecting?
Simply not connecting. It says no network found!
