acerpure Cool 2 in 1 Air Purifier and Air Circulator for Home AC551-50W
  • Views Views 1,066
acerpure Cool 2 in 1 Air Purifier and Air Circulator for Home with 4-in-1 True HEPA filter, Smart Sensor, Negative Ion Generator eliminates pollutants
acerpure Cool 2 in 1 Air Purifier and Air Circulator for Home with 4-in-1 True HEPA filter, Smart Sensor, Negative Ion Generator eliminates pollutants, germs and more,Safety Lock,25dB Quiet, AC551-50W | Acer India Official Store
2–in-1 Air Circulator and Purifier : The acerpure cool deliver filtered fresh air around your home thanks to the purifier and air circulator, CADR (Clean Air Delivery Rate) : 307 CMH.
4-in-1 HEPA Filter, Four-layer Protection : Take control of your air quality with the 4-in-1 HEPA filter and eliminate up to 99% of airborne bacteria, 99.97% of ultrafine dust, PM1.0, and allergies. Against Viruses with HEPA Plus+ : Effectively eliminate 99.99% bacteria, 99.9% anti-coronavirus (229E) 2 and influenza A (H1N1)3 virus activity. The HEPA Plus+ has been certified by the 3rd party research center. Pre-Filter, HEPA Plus+ Filter (Anti-virus & anti-bacterial layer), HEPA 13 Filter, Activated Carbon Filter
Low Energy, High-Performance: with a DC motor, expect high performance of purification at a low energy cost.
Quite Mode : Reduced noise and turned-off display make for the perfect environment for a good night's sleep.
Safety Lock : It comes with safety lock , so you don't have to worry about the mistaken touch by children and pet.
Distant Spiral Air Flow & Easy Swinging : Effortlessly control the direction of your airflow with 90 degrees up and down swing and 80 degrees left to right oscillation. And quietly circulate clean air up to 12 meters
10 Million Negative Ions: Effective Purification : Fill your home with a high concentration of negative ions, capturing ultrafine dust and PM1.0,
Smart Sensor & LCD Display : Put your feet up as the Air Quality & Gas Sensor regulates the purifier speed automatically and LCD displays real-time air quality data.
1 Year Warranty
Country of origin : China
