I am not sure why airtel is blocking my connection to the port 445 while with VPN or proxies its working, i talk to airtel they said we don't block anything but the fact they blocking any idea guys?
Something is blocking between your system and the site. VPN is bypassing it as it's routed thru third party servers.
Have you checked by completely disabling windows as well as third-party firewalls if any. Also fiddle with routers firewall.
Is there any firewall component in wifi or ethernet properties?
Does it happen when you are on mobile hotspot?
Does it happen on both wifi as well as ethernet connection?
I am on airtel and I can access it. I am in Pune right now.
Check with airtel backend experts if they have separate firewalls for separate regions?? Only their firewall experts know what they have configured. rest of the junta field engg have no knowledge and they just beat around the bush
@mayankfawkes Yes, i am on airtel fiber unable to access above link. I recently tried accessing ports 1194, 443, 8080, 80, 21, 22, etc almost every ports are closed on airtel fiber. Contacting airtel backend, they say we don’t block anything. Reality is they are blocking almost all ports, but the sae ports works in bsnl and act.
1) My router have all firewalls disable it says all inbound and outbound is allowed
2) Windows is not blocking anything i tried with my mobile hotspot and its working with bsnl 3g
3) I have a lot of friends using airtel from different states for some its working and some its not
4) Yes its happening on both WIFI and Ethernet
I called airtel they first they said i will transfer your call to senior and even senior don't know anything they keep rotating me to port forwarding i told them its not about inbound i am talking about outbound i tried my best to explain them but later they said i am raising a complain for you, next day a guy visited when i explained him the problem he said sir i don't know about ports, airtel never trained me for such things, i wonder airtel don't even have a technical guy who can understand such things i am so sad for airtel, they should recruit some good educated person who can handle these types of cases.
