AIRTEL BroadBand - Beetel 450 BXI [ Ethernet Problem ]
extinguisher
Hi,My internet is working via WIFIi but when i connect the Ethernet cable to my desktop or my laptop it doesn't work.When I connect the Ethernet cable it keeps acquiring the IP Address : | Do i need to submit any images from 192.168.1.1 ? Thank You
extinguisher said:
Hi,
Address : |
Thank You
WELCOME TO BROADBANDFORUM.IN
appears you have not made settings for LANcard, in both
desktop and laptop.
Start All programs/accessories/ communications
network connection wizard.
follow instructions[/quote]
Then check here:
Start network show all connections
LAN network will appear.
Then
Start Network LAN ( desktop and laptop)
Properties
Network settings page will open
Select TCP/IP
Properties
Check box obtain Ip address automatically.
DNS same entries
or 8.8.8.8 and 208.67.222.222
( google and Open dns )
Apply Save.
Try now
( DHCP to be enabled in router )
Feedback.
REF: similar router See Wa 3002-g4 sticky thread in BSNL forum
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\essbebe>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ABCDE
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : Yes
Ethernet adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Netgear WG511v2 54 Mbps Wireless PC
Card
Physical Address. . . . . . . . . : 00-14-6C-8F-9B-67
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.3
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
208.67.222.222
Lease Obtained. . . . . . . . . . : Tuesday, January 05, 2010 13:03:54
Lease Expires . . . . . . . . . . : Wednesday, January 06, 2010 13:03:54
https://broadband.forum/bsnl-broadband/50052-bsnl-broadband-utstar-wa3002-g4-vade-mecum-quick-reference/
