Airtel Broadband: Netgear Router problem
  • Thread starter Thread starter punter18
  • Replies Replies 12
  • Views Views 6,569
Sorry for the late reply. I have PM'ed you the screenshots of my router settings.I think I should give it a pass, setting Netgear's LAN IP as a secondary one in Beetel. Though one problem that I sometimes am facing with DMZ method is that LAN IP address of Netgear router changes automatically (from 10.0.0.1 to 10.0.0.2 or .3) for some reasons unknown to me. I guess I should also enable the DMZ option in Beetel router as well? As you suggested. As such I am having access to both the routers, so would you still suggest feeding Netgear's LAN IP as Beetel's secondary?
http://img443.imageshack.us/img443/8150/23146534.png
http://img223.imageshack.us/img223/3494/Netgear.png
beetel has LAN IP as 192.168.1.1 by default.
netgear also has same but once it encounters same IP in use it will switch its LAN IP to 10.0.0.1
under basic settings:-------
change the dynamically get IP from ISP to manually put 192.168.1.2 in netgear.
Then goto beetel and uncheck the dhcp in it under LAN settings.
now ur netgear router will only have a fixed WAN IP = 192.168.1.2.......... ( LAN IP OF NETGEAR IS 10.0.0.1)
now in DMZ inside beetel put 192.168.1.2
your computers IP will be 10.0.0.2 or 10.0.0.3 etc...
put this IP in DMZ inside netgear.
So dmz host of netgear is ur comp.
and dmz of beetel is netgear.
beetel forwards all ports to netgear and netgear to ur computer. thats all.
PS-----KEEP YOUR PMs OPEN SO YOU CAN RECIEVE A REPLY.:mad:
That fixed the problem - I hope - I encountered today, yet again.Thanks again and reps added. Also changed the PM settings. :)
