Airtel's Speed-on-Demand has turned all new !. The service has been made really simple by Airtel. Now you don't need to use keyboard at all. No entering complex username and password. The system automatically picks up you DSL ID and IP address of your Broadband connection and you can upgrade to higher speed in just 3 clicks. The rates have also come down .
256Kbps : Rs 10 / hour
512Kbps : Rs 20/hour
1Mbps : Rs 50 / hour
2Mbps : Rs 75 / hour
The interesting thing is that if you are downloading a video or uploading the file, and decide to go to a upgrade to a higher speed thru speed-on-demand, you dont need to restart whatever you were trying to download or upload....the file transfer speeds up from that point itself .In case of a power failure, once you switch to UPS supply , this functionality goes back to the selected speed and one doesn't need to start speed-on-demand again . What more, the service prompts every 1 hour to continue - and in case no action is taken, they auto cut thus eliminating possibility where your forget to switch off Speed-on-demand. And yes, it'll not work unless you are connected to airtel broadband (obviously)!!
Link is Speed on Demand- Internet Speed on Demand: Airtel Broadband VAS
