Airtel fiber low upload speed
Srinagar
From past few days I am getting 20-30 mbps upload speed on my 200 mbps plan.Download is constant 230.It so happens that it goes normal for a day then reverts back to 30 mbps.Talked to customer care they say form their end all is fine.Any idea?
Escalation to Airtel Cares account on twitter may help. DM them and they ususally get back
How many speedtest/different servers you used?
As your DL is fine, I suspect power level might not be the issue, anyway check the power levels for once?
You RX power is good, what about TX (if your optical unit/laser is malfunctioning)
Now that I see you are from Srinagar maybe your upload speed is capped because of politcial policy reasons? Are your neighbours or friends who use Airtel are getting good upload speeds?
I tested on various servers and all are showing same results for UL.
TX 2dBm. My neighbors too have same upload speeds .But my friend living in another sector has normal UL speed.So I ruled out the capping done by the government.
I guess you are LCO based, so before escalting to Airtel, collect your Neighbours and talk to your LCO about this issue together?(OLT capping?)
