Airtel FTTH Fiber Broadband in Sector 31 Gurgaon
Excitel is just better in my area. If Excitel was not there, I would probably stick to Airtel VDSL unless I need the extra speed in which case I guess I would consider Spectra. But then I also have Den Broadband available in my area. It is also not very good but probably would prefer it over Spectra as Spectra push for longer duration recharges which is not something I am comfortable with.
Is this Airtel FTTH cable? black with yellow stirpe and Bharti Airtel written on it... Seeing it finally in Bengaluru
i guess. coz they now have fiber to the box near my house. but still no fiber to the home. still stuck on vfiber which is pretty bad as i had to suffer through it last night. link went down several times during the night for a few minutes and overall browsing experience was quite bad. there is some packet loss but not enough to explain the shitty browsing experience.
@Sushubh we can't trust on brochure or app. In Bangalore, they used to put xstream fiber brochure in my building flats. But when I booked, the installation guy said the connection is v-fiber and plan speed will be max 40mbps only. After activation, app was showing I am on 40mbps plan but I had option to change plan to xstream speed plans 100mbps to 1 Gbps options. I tried to change the plan couple of times for few days but it failed. After contacting the customer care and then Nodal authority, they notified me my premises had v-fiber only and they also removed xstream plan options from the app for me.
Box outside my house.
So which fiber plan will you sign up for? go for gigabit!
