I am on an Airtel Xstream Fiber 200mbps plan. Apart from the specific time frame mentioned in the title, it works great. The speed is fine, the ping is low(good enough for video calls and games). Currently, I have a ZyXEL ONT router and two lan cable connections. One for a TP-Link Archer c6 and one directly in my laptop.
The ping is pathetic between 9-11/11:30pm EVERY NIGHT . I complained, put in a request to find out the problem. First they tried the classic old "Router Reboot". Then they said they are gonna reduce the optical power. And finally they replaced the router.
The "fixing" process started on the 8th of september 2022. Till date, they have not been able to identify the problem. I have tested the ping on my laptop. Its connected via a lan cable. Its on a metered connection too. No background downloads or auto updates during that time frame too.
Can anyone help or has any knowledge on this matter ?
P.S. - By pathetic I mean , In valorant/apex/R6 i get 400ms during the said time frame. On Ookla, I get 50-100 mbps on a WIRED network. Discord Ping also goes to 400ms.
