AIRTH Smart Home AQI Monitor
  • Replies Replies 3
  • Views Views 1,572
Likely a rebranded product from China? I mean who would make a product with microusb today.
And yes.
Selling a 1500 rupee product for 4500. Jai bharat.
Real-time monitoring: This air quality monitor provides accurate and real-time monitoring of PM2.5 concentration, temperature, and humidity.
Easy to read: Equipped with a digital tube display, the Airth monitor makes it easy to read and understand the data.
Portable design: With a compact size of 100 x 95 x 47mm and a weight of just 1.68kg, the Airth monitor is easy to carry around and use in a variety of settings.
Quick and accurate: Thanks to a sampling time of just 1.5 seconds, this air quality detector provides accurate and quick readings.
Multifunctional: In addition to detecting PM2.5, the Airth monitor also measures temperature and humidity, making it a versatile tool for monitoring and improving air quality in your home or workspace.
Discovered it through a listing for AC Air Purifiers "Developed at IIT Kanpur & IISc Bangalore".
AIRTH Air Purifier for AC, Coated HEPA filter with proven protection from PM2.5, PM10, Viruses, Allergies, Made in India, Developed at IIT Kanpur & IISc Bangalore
this is an air quality monitor :|
if you are asking about their product that is supposed to be placed above split acs? i wouldn't recommend it personally. first it is stupid to run ac even in fan mode in winters. and yes, it would reduce air flow and might actually damage the ac.
