Amazon Fire TV Stick
  • Replies Replies 65
  • Views Views 29,778
thats why I kept asking if its possible to buy it without voice remote. Amazon should have kept it optional that way the price would have stayed low. Everyone will be using mobile as remote only
well you need the remote to connect the device to wifi and your account. the app only seems to work after that has happened. at least that was my experience. the app was useless when i resetted the device yesterday.
Californication was definitely censored when Prime Video launched. I checked :D If they have removed the censorship, cool!
I think if you use parental control, and set a pin for access, then it gives the uncensored version. Maybe you can check otherwise. I can see the uncensored version after doing this.
Only wireless bluetooth mouse is an option(not sure if at all it will work). So if you install an app meant for mobiles you may not be able to use it on fire tv stick. However, if the app is meant for Android TV OS, you will be able to navigate the app using stock remote.
