Any Tips Advice/Help In Using This Connection? (TriplePlay 100 Mbps Unlimited)
  • Thread starter Thread starter Bolt
  • Replies Replies 8
  • Views Views 1,672
Airtel Xstream
If any of you have been following my threads, you might know that I have been struggling to get a connection at my home in Gurgaon patel Nagar.
Finally though I have got a connection from Tripleplay, which is the only ISP the LCO provides.
Its FTTH and giving decent 90+ mbps speeds on most servers on 100 mbps plan.
Do any of you experts have any tips advice for me about what to take care of and what equipment settings to use for best experience?
Regards
His review helped my strengthen my Decision of getting its connection, although it also got delayed by 2-3 days, but it's mostly to blame on Holi rather than anything else.
Can you advice on a decent router ~2k price for a 100 mbps connection??
Preferably AC.
@vignesh_venkatesan It is available for me......
BTW JB700 mentioned there's no censorship on this ISP but for me not a single torrent site is working outside of VPN, not even my organisations p2p site is working.
Yep, I was wrong there. I didn't realize that I had zarpet bol-van/zapret enabled on my pc when I was writing the review and testing sites. Unfortunately, Tripleplay uses Airtel backbone and you'll get HTTPS TCP Reset blocking on it :(. I later realized this but forgot to edit the review. Sorry for the mistake I'll correct it right away.
