I asked airtel for static IP today but I am using Huaweirouter in bridge mode with Tenda one. They will do everything through their end only I guess. So is it going to make any kind of trouble for me to get static IP with bridge mode?
Not sure because static IP is generally against a CPE mac address or subscriber ID. You better talk to Airtel support to check if MAC cloning is essential. In my case the Airtel Nokiarouter works in dual mode..it establishes a PPPoE connection itself as is default and one LAN port is switched to bridge mode which I use to connect my Asus router. I have switched off wifi on the Nokia and use it as a dumb ONT though I must say I could connect another device via its wifi or LAN port to get another IP/connection.
No I am on dynamic. I don't need a static neither do I want one at least for now. I could get one from Tata Sky for free (IPv6) but I prefer not to get locked down to 1 public IP address.
okay,so when they will be configuring my ont through their end and making it static connection, they will basically reconfigure the WAN settings and fill it with static settings right? And then I can take the credientals from there and put it in my Tendarouter which is connected through bridge mode and the tenda one will also have static IP. But the question is, both the routers will have the same static IP? or different? or what?
@nishantt6969 bro you better check with Airtel about the exact method to configure the routers. This seems to vary from CPE to CPE. With subscribers using Nokia they use a very different method of implementing bridge mode unlike what most other ISPs do.
