Artis AR-MINIDC-3 Mini UPS
  • Views Views 1,276
Artis AR-MINIDC-3 Mini UPS for WiFi Router/Modem/CCTV/Set top Box/POE Devices. 8800mAh Battery. Supports 9V/12V-1A/1.5A/2A Routers. USB Port Phone Charging.Battery Level Indicator. BIS Certified
Compact & Lightweight Mini UPS with battery level indicator, 8800mah battery & upto 8 hours backup for Wifi Routers, Modems, CCTV Cameras, DTH Set Top Boxes, POE Devices & USB Smartphone Charging. Router support: 9V/12V-1A/1.5A/2A. POE Support: 15V/24V. USB Output: 1.7A Max.
Massive 8800mah battery provides upto 8 hours of backup. Battery Level indicator helps check charge/backup Level. Compatible with All 12V and 9V Routers with 1A / 1.5A / 2A Input Requirement. (Please check your Devices Power Requirement on its original Charger, Please refer user manual before first use)
Uninterrupted Lag-Free Backup during Power failure. Micro Load detection ensures no cut off even with micro loads such as only Wifi routers. Over-charging and Deep discharge protection - Ensures that Internal battery is well protected against any malfunctions. BIS Certified, CE, FCC, ROHS Certified Product. 1 Year Manufacturer Warranty from Date of Purchase.
Power cable provided to charge the UPS Directly. Not Dependant on Router Charger. Output Y Cable can provide Backup to 2 devices simultaneously such as Modem & Router. 2 Output Bridge Connectors Provided for additional Compatibility. Compatible with all Leading Brands such as TP-Link, D-Link, Netgear, Cisco, Asus, Tenda, Lnksys. Zero Lag Switching - The UPS ensures switching between main power and battery happens without any delay
For Any further assistance, please read the user manual or get in touch with us at inquiry@artis.in Or 1800 123 8195. NOTE: Please check the compatibility of your devices before purchasing. This UPS supports 9V and 12V output, it supports 1A/1.5A/2A Output. It supports 15V and 24V POE output and upto 1.7A USB charging Output.
Other variants:
Artis PS-1000Eco 1000VA (1KVA) Line Interactive UPS for Personal Computers, Desktop PCs, Laptops, Routers, Networking Devices and Gaming Consoles
Artis PS-600VA 600VA Line Interactive UPS for Personal Computers , Desktop PCs, Laptops, Routers, Networking Devices and Gaming Consoles
