Authorization Failed! Weird problem
  • Thread starter Thread starter genexed
  • Replies Replies 6
  • Views Views 5,863
genexed
Regulars
MTNL 512 combo unlm + TATA 1 Mbps UNLM
Since last 3 days im getting a weird problem on MTNL Line. Router only connects alternately, what that means is lets say my router is connected and if I switch off and on the router it will not connect unless I switch off and on again. Log shows error Authorization Failed.
I have 3 routers and all are giving same problem. Since my Belkin routers keeps trying so Im able to connect with belkin without having to replug. Heres the belkin log and it clearly shows that MTNL didn't auhtorize my pw few times but it did eventually
[MOST RECENT ON TOP]
08/01/2003 20:47:26 If(PPPoE1) PPP connection ok !
08/01/2003 20:47:25 PPPoE1 get IP:XXXXXXXXX
08/01/2003 20:47:25 Username and Password: OK
08/01/2003 20:47:24 PPPoE1 start PPP
08/01/2003 20:47:24 PPPoE receive PADS
08/01/2003 20:47:24 PPPoE receive PADO
08/01/2003 20:47:24 PPPoE send PADR
08/01/2003 20:47:24 PPPoE send PADI
08/01/2003 20:47:24 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:23 PPPoE send PADT
08/01/2003 20:47:23 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:23 Username and Password: failed
08/01/2003 20:47:23 PPPoE stop
08/01/2003 20:47:22 Drop invalid PPPoE-Session packet coming before PADS.
08/01/2003 20:47:22 PPPoE1 start PPP
08/01/2003 20:47:22 PPPoE receive PADS
08/01/2003 20:47:21 PPPoE receive PADO
08/01/2003 20:47:21 PPPoE send PADR
08/01/2003 20:47:21 PPPoE send PADI
08/01/2003 20:47:21 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:19 PPPoE send PADT
08/01/2003 20:47:19 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:19 Username and Password: failed
08/01/2003 20:47:19 PPPoE stop
08/01/2003 20:47:19 PPPoE1 start PPP
08/01/2003 20:47:19 PPPoE receive PADS
08/01/2003 20:47:19 PPPoE receive PADO
08/01/2003 20:47:19 PPPoE send PADR
08/01/2003 20:47:19 PPPoE send PADI
08/01/2003 20:47:18 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:17 PPPoE send PADT
08/01/2003 20:47:17 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:17 Username and Password: failed
08/01/2003 20:47:17 PPPoE stop
08/01/2003 20:47:16 PPPoE1 start PPP
08/01/2003 20:47:16 PPPoE receive PADS
08/01/2003 20:47:16 PPPoE receive PADO
08/01/2003 20:47:16 PPPoE send PADR
08/01/2003 20:47:16 PPPoE send PADI
08/01/2003 20:47:16 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:15 PPPoE send PADT
08/01/2003 20:47:15 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:15 Username and Password: failed
08/01/2003 20:47:15 PPPoE stop
08/01/2003 20:47:14 PPPoE1 start PPP
08/01/2003 20:47:14 PPPoE receive PADS
08/01/2003 20:47:14 PPPoE receive PADO
08/01/2003 20:47:14 PPPoE send PADR
08/01/2003 20:47:14 PPPoE send PADI
08/01/2003 20:47:14 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:12 PPPoE send PADT
08/01/2003 20:47:12 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:12 Username and Password: failed
08/01/2003 20:47:12 PPPoE stop
08/01/2003 20:47:12 PPPoE1 start PPP
08/01/2003 20:47:12 PPPoE receive PADS
08/01/2003 20:47:12 PPPoE receive PADO
08/01/2003 20:47:12 PPPoE send PADR
08/01/2003 20:47:12 PPPoE send PADI
08/01/2003 20:47:11 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:10 PPPoE send PADT
08/01/2003 20:47:10 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:10 Username and Password: failed
08/01/2003 20:47:10 PPPoE stop
08/01/2003 20:47:09 PPPoE1 start PPP
08/01/2003 20:47:09 PPPoE receive PADS
08/01/2003 20:47:09 PPPoE receive PADO
08/01/2003 20:47:09 PPPoE send PADR
08/01/2003 20:47:09 PPPoE send PADI
08/01/2003 20:47:09 If(PPPoE1) PPP fail : PAP authentication failure
08/01/2003 20:47:07 PPPoE send PADT
08/01/2003 20:47:07 Send PADT in response to invalid PPPoE-Session packet.
08/01/2003 20:47:07 Username and Password: failed
08/01/2003 20:47:07 PPPoE stop
08/01/2003 20:47:07 PPPoE1 start PPP
08/01/2003 20:47:07 PPPoE receive PADS
08/01/2003 20:47:07 PPPoE receive PADO
08/01/2003 20:47:07 PPPoE send PADR
In the WAN page of modem/routerwhere UserId PW is entered ( usually )change authentication to "AUTO"Others PAP /CHAP/ MSCHAP
ESS...I have tried that option already. Tried my tata router(4th router) as well and similar problem. hmmm Call to cc and confirm it ? you must be kidding me!!! You think they even know what it means ? It will take me 1/2 hr to explain to them what the problem is and even if they understand they won't be able to help in anyway. Ashish..do you stay close to south delhi ? can you pm me your contact no, seems we have lot of things in common when it comes to MTNL conenction.
yaar, i'm in Ashok Vihar, Nortth-west delhi.... MTNL delhi have single server/control-unit, n thats at Janpath, thats y all delhi will have same problem... its unlike bombay....n check ur pm...
