There was another update of about 1.7MB (build nmber JWR66Y)Dextermorgan said:I already did factory reset ..then got OTA update of 4.3 ..installed it and then this battery problem started.
Tablet runs buttery smooth ..all the apps work without even a slightest hint of lag ..Its just this battery drain which is troubling me past 2 days
I've just got this update after manually searching for it in settings. Installed it ..would know tomorrow whether the battery drain is fixed or notvspraneeth05 said:There was another update of about 1.7MB (build nmber [color=rgb(40,40,40);font-family:'Droid Sans', helvetica, arial, sans-serif;]JWR66Y)[/color]
OR, Try a custom Kernel. I use Franco kernel left it untouched at 100% for 26 hours and the battery decreased to just 99%
sahibunlimited said:Did you check your processor speed with cpu spy?
Don't have real racingSupernatural said:wakelock detector , spu spy are your two options. I have N4. Had this issue. "Keep awake" is your issue with the tablet and it's quite famous , as well as annoying issue.
What I understand is , you did the reset, and then updated.... I say, do a factory reset again after the update ( the update won't be gone after then reset ).
and Do check your phone apps settings.
Also, real racing 3 is one of the game which also causes the issue as I doesn't exit properly. Force stop it if you have the game.
It shows for what period was your CPU on different frequencies. You took the screenshot too soon, didn't allow the tablet to idle. Let the tablet idle for 1 - 2 hours and post the screenshot again. You should be able to see one more section called 'Deep Sleep', something like this.Dextermorgan said:Not sure what the above screenshot means.
Being lazy won't solve your problem. Update to the latest update and then reset the device. I had the exact same problem 2 days back. Reset worked and now I'm having 5hrs and 20 mins SoT on my N4. ( With 1Day and about 18hrs of phone usage - not much games, may be for 20 mins max, 3g usage for a hour and then normal calling. ) 4.3 update sure has done great.Dextermorgan said:Would be too much work to again reset the tab. I've got an update ..If this doesn't fix ..I'll do the reset this weekend.
