Hello,
I have been using Beam Fiber for 2 years now. Starting last week, I have been having issues with the connection. The connection is good for couple of hours and drops there after. The portal page does not open either. I have to disable the adapter and/or reboot the router. The techs came and reset their modem. Has anyone had similar issues? These issues have come up just when I wanted to upgrade to the 50Mbps plan. I have been using Asus the RT-N13U.B1 router with the dd-wrt firmware. Initially I had thought that it was a router issue and went ahead and bought a replacement but am having the same issues. Any help is appreciated with configuration or tips to rectify this issue.
Thanks,
Mohan
Thanks,
Mohan
