Best portable charger and multi-plug USB outlet?
  • Thread starter Thread starter Crazysah
  • Replies Replies 12
  • Views Views 2,629
Crazysah
Arsenal FTW!
ACT Fibernet 300Mbps
Hello,
What is the best portable charger and multi-USB wall plug I can buy today from somewhere in Delhi or preferably Amazon/Flipkart?
Budget for portable charger: 3,000
Budget for multi-USB wall plug: 1,500
Thanks,
Crazysah
x720: No, we were trying to find a AC Mains based charger which can charge multiple device at one place.
after my Anker 5 port one went dead one port after one, I was looking for another
after finding a few good reviews of portronics one, decided to buy one
Portronics POR 343 Battery Charger (AKA UFO charger)
Delivered very promptly, within 48 hours,
Works fine in charging multiple devices, Max I get on each port is around 1 Amps (900 to 990 mA) when using branded USB Cables or OEM cable
which comes with phones.Get 500ish mA when charging with after market cable.
I've tried using all 6 ports at the same time, and it doesn't affect charging speed.
6 L.E.D. lights are way bright and you can see them on ceiling.
In All its a value for money product if you have multiple devices and don't want a dangling charger & cable at every other power outlet in your home.
