Best Router for Airtel Fiber Connection
Understood. I'm currently stuck with the Alphion ASEE-1447 which (imho) is severely underpowered.
I see 2 options for me and option 2 is what prompted my question.
Option 1. (preferred) Have Airtel enable bridge mode, then connect a router like the GL.iNet Beryl AX (or a Flint 2) to the bridged port, and configure PPPoE with their VLAN id (100 per the Alphion UI) on it. I'd be satisfied with this and have full flexibility on the router.
Option 2. (fallback, if Airtel won't enable bridge mode) Replace the ONT with a 3rd party ONT. I understand a lot less here in picking a compatible and good unit. I saw you (tr1k0N4) recommended the TP-Link XX530v in a different thread with some caveats. Can this replace the Alphion ASEE-1447? You mentioned "no support for IPv6 VoIP and IPv6 address not being assigned to Mobiles etc". I do care a lot about IPv6 (but no VoIP). What happens with IPv6 addresses and mobiles? What other issues? I do link TP-Link units, so perhaps there's another model without these limitations?
An XX530v can definitely replace any ONT Airtel provides.
What's your exact budget?
And if you go with option 1, Airtel shitheads will ask you get a static IP first 🙂
Nokia AOT4221NK is way better but locked asf, which I'm sure the classic Nokia is as well, now, given the number of firmware updates Airtel pushed on it in the recent past.
I am using ZyXEL on Airtel broadband and easily getting 1Gbps on wifi using 5GHz wifi band over 160MHz operating bandwidth.
I have ordered 2.5Gbps ONT from Alibaba, I don't want to disclose name though and I will connect it with my recently ordered flint 2 which I will recieve next month
Is it worth to upgrade Nokia G-2425G-A to Nokia AOT4221NK in present scenario, Heard there are some open firewalls in Nokia AOT4221NK. Pls suggest.
