Best way to monitor uptime for JioFiber Connection
  • Thread starter Thread starter TinTinSnowy
  • Replies Replies 9
  • Views Views 1,420
Do you have some device like a pc or raspberry pi etc which is always on and connected to the network?
a simple script on RPi should do the trick. ping every minute and record no response timestamps, can also trigger email/SMS for outages
For monitoring uptime plus other stats you can host a Ripe Atlas Probe as well.
Done, did the config and applied for sw probe. What else should I do? Its showing my probe in the list but not showing any IPs or uptime/downtime.
edit : now its showing, thank you for the reply.
