You forgo WiFi thing and connect LAN directly to Lpatop, and still can't ping gateway ???If yes then it is an issue with TATA everything's okay at your end.
Yes inspite of the physical connection i was not able to ping the gateway .... you are right ... seems some issue with TATA BB.Well we close this thread. Thanks for your help.
