Hello,
I currently use internet via bridge mode on my PC, its working fine. I use dialer to connect to internet. No issues.
But I can't access the Router settings Page(198.168.1.1)
Now i have bought a new iPod Touch, as it supports Wi-Fi, i needed to connect modem in PPPoE mode for a always on connection with dataone id/pass in modem settings.
Now i configured the modem for PPPoE(by reseting the modem as i can't access router page on PC),
but can't browse internet on PC.
But i can use the internet on my iPod and can access router settings page.
Where can be the problem?
Using windows XP SP2 with ITI DNA A211-1(wifi) modem and iPod Touch.
I have to switch between bridge and pppoe if i have to use internet in PC and iPod. this is getting on my nerves
kindly suggest what to do.
Some info to start with--
C:\Documents and Settings\yogesh>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Realtek RTL8168/8111 PCI-E Gigabit E
thernet NIC
Physical Address. . . . . . . . . :
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.2
DNS Servers . . . . . . . . . . . : 192.168.1.1
PPP adapter dataone:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : Some address
IP Address. . . . . . . . . . . . 0
Subnet Mask . . . . . . . . . . . : 255.255.255.255
DNS Servers . . . . . . . . . . . : 218.248.255.212
218.248.255.139
NetBIOS over Tcpip. . . . . . . . : Disabled
In short
I want to access internet in pppoe mode on PC.
Access the router settings page on PC(any mode).
thernet NIC
218.248.255.139
In short
