BSNL broadband does not work with Ubuntu 14.04
  • Thread starter Thread starter ashwin_d123
  • Replies Replies 75
  • Views Views 8,414
Only thing I can assume is there is something wrong with new setup of your Teracom modem. WiFi may not be enabled. That could be the reason you are no seeing your SSID ( network name ) in wireless indicator.
Since the SSID is working and is able to spot on the laptop, try the same process I gave with WiFi adapter. Just use IP address as 192.168.1.30 this time.
We are going to try with D-Link modem because quite honestly we are fed up with BSNL modem. We also tried with Baton modem and that did not work. So D-Link works in my friend's house. So we thought he will use Baton and I will use D-Link. Hopefully D-Link will work and that solves the problem.
Currently BSNL modem works LAN and wired on both Ubuntu and windows.
You could try enabling DHCP in your Teracom modem. I think that is causing these issues.
Yes, enable DHCP. You will have to assign IP to every device manually if DHCP is not set to automatic.
