My BSNL Broadband Modem -ITI -DNA-A211-I stopped functioning after a lightning. It's power cord indicator started blinking with no indication on the modem. When I opened the modem, two capacitors placed adjacent to each other were found broken. Its outer coating was scattered inside in very small pieces and hence capacitor number and make could not be found out. If I replace the capacitors with new ones, will the modem work? If yes, please suggest the spec of capacitors which I should buy.
