BSNL broadband net connection problem with linux F10
  • Thread starter Thread starter priety
  • Replies Replies 1
  • Views Views 4,225
priety
bsnl
Hello,
i am using bsnl broadband bridge mode, i recently installed linux fedora 10.
i am unable to connect to the internet. m getting following problems....
* shud i use ethernet or adsl while running setup in system->preferences->network?
* do i need to specify my login name and password while configuring ehernet just like i do in bridged mode in XP ?
* what shud i specify as login name a_b or a_b@dataone or [email protected] ?
* can i keep both usb and ethernet cable attached to comp while using inet ?
* can neone explain the ethernet configuration process in fedora 10 ?
please reply as soon as possible...
thank you...
make sure u really set bridge mode
run this as root
Code:
pppoe -AIeth0
it shud show some access concentrators, if not then most likely u havent set bridge mode.
if it does show access concentrators, then run this:
Code:
pppoe-setup
and answer the questions. i dont know abt username in BSNL may be otehr BSNL users can answer.
finally, run
Code:
ifup ppp0
and ur connection shud be up. after 30seconds
Code:
ping google.com
