BSNL Broadband: plz help me configure wifi on DNA-A211-I modem
  • Thread starter Thread starter active2512
  • Replies Replies 7
  • Views Views 11,085
active2512
dataone
please help me configure my DNA-A211-I modem in order to use wifi on my Nokia 5800.I have tried to configure my phone and modem but i'm getting the reply "no gateway reply " on my phone.I need help to configure the modem.plz help.
1. If you are on dialer mode change to PPPoE "always On " mode.
2 Enable dhcp in router.
3. Check your network name appears in Nokia 5800.
4. Enable UpNp in router.
REF:
see the "sticky" post for WA3002_g4 in this forum
modem/router/WIFI settings are same.
Feedback.
I have changed the modem to PPPoE "always On " mode.but for enabling dhcp in the router the following details are required Start IP Address: End IP Address: Subnet Mask: Leased Time (hour):Also i couldn't find an option to enable UpNp in the router.My network name came in my phone and i was able to connect also.But getting the same reply "no gateway reply".
Start IP Address:192.168.1.2
End IP Address:192.168.1.10
Subnet Mask:255.255.255.0
Leased Time (hour): usually default 0 or 24x60x60 seconds
Also i couldn't find an option to enable UpNp in the router. see sticky post wa3002-G4 in this forum ) may be in LAN page :Important.
Feedback for above
finally i'm able to connect to the net over my phone.Thanks a lot essbebe and india broadband forum.
REF:
Feedback.
:confused: hey buddy how can i do these steps plz tell me in detail
did you see the "sticky"link for WA 3002-G4
select Chennai link with screen shots.
DHCP will appear in LAN page.
give range 192.168.1.3 to say 192.168.1.10
save reboot wait for 2 minutes.
