sanjukholia
I got my broadband connection from bsnl installed on 5/10/11 .
BSNL sent some civilian guy ( not from bsnl ) to install my broadband ( phoneline was already installed )
. I had to buy a TP-Link modem (TD-8817) from him because he told me bsnl wont be renting modem .
I use Asus RT NI6 router to share the internet using wireless n wired connections throughout my home.
Modem was configured to bridge mode . Asus router was configured for pppoe connection and acted as gateway.
The net worked very fine for a few days .
The SnR (12 db ) n attenuation (50 db) of my line r bad , but the net works fine still .( i will get a lineman to fix this soon but a bigger problem needs to be tackled before that ) .
The modem stopped working after 4-5 days . I called the civilian guy and he took my faulty
modem n gave me a modem ( ITI limited, DNA-A201BE ) which has bsnl stamp on it, temporarily .
I also had a UT 300 r2 modem from 2 years before which i decided to unpack after this modem failed .
Now the problems started to occur :
When i use my UT 300 r2 modem , the downstream rate is very low ( i tried to change modulations
, adsl2+ is the only stable connection on my line , g.dmt n others give higher speeds but r unstable )
. When i connect this to my asus router ,the connection BW ( bandwidth )is stable but very low .
When i use the bsnl modem ,i get good downstream rate (adsl2+) , and the net works fine
when i connect this modem directly to 1 PC .
The problem in this case arises when i connect this modem to my router , the speed of
operation is still good , but the net goes to ~0 kbps for about 1 sec every 10 second or so .
It is a very peculiar problem : UT modem gives stable connection to 1 PC and through
router too ,but is not operational on this bsnl line .
the bsnl modem operates well on the line ,operates well when connected to 1 PC but
when connected through router ,gives 1 sec lag periodically
ScreenshotImage - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting.
I believe only specific modems work well with the condition of my bsnl line ,
so maybe the TP link modem will still operate well on it .
But the contact no. given by that civilian merchant no longer works
( I have the bill for equipment ,shop location given refers to a big area n no shop
in particular so that doesnt help either ) (so he was a fraud maybe ,i'll still try to track him ),
so instead of trying to buy another modem ,i wanted to know if their is a way
to get the bsnl modem that i have to work properly when connected through router
( ie. eliminate the periodic 1 second lag ) .
Would be very grateful for any kind of helpful info .
modem works on bridge mode ,adsl2+ modulation .
asus router works in gateway mode ,with pppoe wan configuration seetings .
PS : sorry for the wall of text but the problem is pretty weird .
