Bsnl downloading speed is good but upload speed is not good
Dibendu Gorai
:cry::cry::cry::cry::cry::cry::cry::cry::cry: PLS help if anyone can increase the upload speed as downloading speed :ishock::ishock::ishock::ishock::ishock::ishock::ishock::ishock::ishock::ishock::ishock::ishock:
I used to get an upload speed upto 150 Kbps when the download ranged to 550-600 Kbps - Pre-Maintenance speed change....Now i get about 30-45 Kbps Max while the download touches a max of 115 KbpsBtw I dont think u can increase Your Upload speed unless u get a Fixedline Broadband connection...Most Wireless players concentrate on download speed and not upload speed..and that's too bad cause BSNL 3g also comes under that category........
If you want good upload speed, just shift to Reliance.Upload speed more than 1 mbps.
on umg1831 data card i get between 0.4 to 0.9 mb. but on teracomm i get around 0.2 to 0.3 mb
The upload speed is restricted to 512kbps..Then how are you supposed to get upload speeds equal to 1Mbps download speeds...
i checked it with my umg 1831 . May be state wise this speed vary .I setup may pc as a web server with 3G connection and downloaded one small file from another PC . that time i got 1 Mbps download speed that means My 3G connection is uploaing file at 1 Mbps .
