BSNL - EVDO - Usage - Review and everything about it
  • Thread starter Thread starter MediaFire
  • Replies Replies 244
  • Views Views 93,267
Status
Not open for further replies.
Teracom tu-500 modem is a good device. Buy 1.5m usb extension cable and search for appropriate place where you get maximum speed because evdo speed veries place to place even 1cm matters....
Thank you so much now i am getting around 800-900kbps speed consistently. One more help can you suggest which plan should i choose and how, 750 or 838 for prepaid unlimited.
If you want to use unlimited plan always and not want to use other plan than go for 750 unlimited. If you want to use different plans like 2gb 3gb 5gb than you are on general plan in which you have to do particular plan stv.... I am on 750rs unlimited plan. You are normally on general plan if you want to activate any plan permanently like 750rs than you have to visit bsnl exchange.
Since last 3-4 days my taracom modem is disconnecting abruptly despite of 4 evdo signal bar can anybody tell me how to solve this? Do i have to buy different modem if yes then tell me where i can buy btw i am now getting upto 60-300kbps download speed but the only downside is frequent disconnection
Status
