BSNL Fiber FTTH ONU recommendation for using BSNL voice with FreePBX
  • Thread starter Thread starter ragveer
  • Replies Replies 4
  • Views Views 97
Nalgonda
BSNL, Airtel, Jio, Excitel
Hi everyone,
I am planning to take a BSNL FTTH (Bharat Fiber) connection and BSNL has asked me to use my own ONU/ONT.
My requirement is not just internet — I also want to use the BSNL Fiber voice with my FreePBX setup, which is running on Proxmox.
So I am looking for an ONU that supports:
  • GPON / XPON (for BSNL compatibility)
  • Works reliably in bridge mode with my own router (openwrt)
  • Easy integration to Freepbx for voice
Kindly suggest:
  • Which ONU models are known to work well with BSNL FTTH
Any model recommendations or real-world experiences with BSNL FTTH + FreePBX would be very helpful.
Thanks in advance.
i have followed this post and it was easy peasy lemon squeezy to make bridge connection - just dont forget to clone PPPOE mac address into your router
thank you for making it very simple @!!..PD..!! wooh!
I’m looking for guidance on configuring BSNL FTTH Voice to work with FreePBX running on Proxmox, so that I can make and receive inbound/outbound calls using FreePBX instead of the ISP ONT.
Current Internet & Network Setup​
  • ISP: BSNL FTTH
  • ONT: Syrotech ONT
    • Internet VLAN is bridged
    • VOICE / TR069 (VID 1831) remains in route mode
  • Network path:
    • ONT (internet bridge)
      TP-Link TL-R600VPN (multi-WAN router)
      → OpenWrt router
      → Unmanaged switch
      → Proxmox host → FreePBX
Virtualization & PBX​
  • Hypervisor: Proxmox VE
  • PBX: FreePBX running as a VM
What I want to achieve​
  • Use BSNL FTTH Voice (SIP) directly in FreePBX
  • Enable inbound and outbound calls
  • Understand:
    • Whether BSNL SIP credentials can be used in FreePBX
I’m aware that BSNL typically provisions voice on the ONT, but I’m trying to understand if there is a supported or workable method to register BSNL Voice on FreePBX, or if this is technically blocked.
Any guidance, real-world experience, or references would be greatly appreciated.
Thanks in advance for your help.
