BSNL:Wierd UsageCounter&Billing,Will I be Charged ?? plz help
  • Thread starter Thread starter abyssman
  • Replies Replies 6
  • Views Views 2,215
abyssman
BSNL- HOME 500 C+
Hi Friends..
I took the BSNL Connection with 500 C plan ....... this is the 3rd time i am taking the same connection but b4 had never came across the problems which i am facing now....
i got the connection on 4th august...... i did a big mistake swithching on the router b4 2.00 am.. i was early by 2 mins and the bandwidth that time the usage has been counted .... i.e.(1.59 -2.29 am )
The Image is Shown Below:
http://imageshack.us
http://g.imageshack.us/g.php?h=217&i=bsnl2dx9.jpg
1st day it was just 180 mb .. thought i can manage n there's no need to complain coz the limit is 1.5 gb..........
tho i was careful.. i swithced on the modem on the 3rd day 5 mins late ( i switched it on at 2.05 am aaj tak time , i had sync my pc time with it..)
but stilll the usage has been counted ,,, and shockingly its counted 400mb with in half an hour on 8th aug ( 1.58 to 2.29 am )... its impossible to download 400 mb with in half an hour coz max i get 120 kbps ...
The image is shown :
http://imageshack.us/
http://g.imageshack.us/g.php?h=217&i=bsnl1ze4.jpg
I tried to call bsnl.. at 1957 and there was no response and atlast some one picked at the other number and said
" BSNL does scan the usage Once in 5 hours.. (unlike b4 it used to scan every 15 mins ) and hence it does count in sessions .. so it has been counted.. "
and they said during billing .. if i approach the main branch they will reduce it..... ( I Wont belive this fact )
and they also said that they cant assure it.. and i dont rely on them coz i have suffered b4 with the similar problems, such as getting back the deposit and some billing problems....
Do u think they'll charge me.. or should i , on the safer side shouldn't exceed the bandwidth... coz already 850 mb used out of 1.5 gb with in 4 days......
I think they use some dumb software for counting the usage..
when its meant for free b/w 2-8 they should completely make the usage zero... b4 it used to never count the usage tho d connection was made before 2 am(i.e when b4 one year or so).....
plz help me out....
**** and also tell me .. to find out whether the connection is Port binded ... or is it the setting which has to be done explicitly by me doing some tweaking ....
i hope the board members will help me out...coz u have helped me in the past to...
I thank you in anticipation
- Abhijith
well bsnl does use a buggy software & that's why this problem.i see that you are using old portal to check usage.try this new portal BSNL Portal & check usage.export the results to excel by clicking on the export to excel button.open the excel file(not with excel 2007 because it won't show MAC address as such in table & you have to click on each cell to see it)& under MAC address colomn confirm that MAC address shown in front of entries is that of your computer.MAC address/physical address is something like 00:1a:23:45:67:df & is unique for every computer.you can find MAC address of your computer by typing ipconfig /all in command prompt window(type cmd in run box to get this window).
@/whitestar_999/Can you kindly post a screenshot of the usage page with MAC address .You can blank it partially. I have suggested your post to find an alleged "Hacker".
i changed extension of saved excel file to .html & opened it in firefox as excel 2007 doesn't display the full contents of cells under MAC address colomn.i think excel 2003 don't have any problem.
Thanks for replying white rat....i did check my usage from the mentioned site ....... but there is no difference in the usage.......... only difference is GUI Is improved and enhanced.....they would have a single progy which counts the usage...My question was .. will bsnl count the bandwidth used in that time .......coz its there technical fault or failure to do the required calc.. will i be charged ?n about port binding ? thanking u in advance ...abhijith
@abyssman,not only the GUI is improved but it also has the MAC address of computer used for each usage entry.you can see this in the exported excel report which will have a MAC address column.if you find out that some entries have a different MAC address than your computer you can use this as an evidence to show bsnl that your account was hacked & those entries were used from another person's computer & they will most probably correct the bill.
