i suggest everybody to connect there phones at 3.00am in the night just to understand that the 247kbps connection is not myth... now i've also heard a thing called "edge" and "non-edge" area... better do a double check with your service provider...
take my advise... if your phone shows an "E" while connected then use the above trick.
normal "G" users, ignore this... u don't have EGDE in ur area...
460 kbps is the port speed...
not true... or maybe ur referring to the performance of the older phones
just to let you know... i have a hutch billing connection... i got about 247kbps... i downloaded a 500KB file in a nearly 15 seconds
also i downloaded it on the phone and not on my pc but that doesn't make any difference... hutch is no good by the way... here also 247 is not always
in west bengal where EDGE is available the download speed is not as much as you say.
you say you download 500kb file in 15 sec. this speed is 33kbps not 247kbps.
