go to the network folder there click on the setting of ur EVDO connection
http://img145.imageshack.us/img145/8329/000000j.jpg
then click on allow other device.... and choose the lan connection . as shown in the picture ...
http://img98.imageshack.us/img98/7201/0000000v.jpg
before that make sure that u did not manually configured ur lan connection . choose for auto configure . and the computer will automatically configure the lan ip to 192.168.0.1 .
now connect the router to the lan port with the cable supplied by the vendor . To configure the router please follow the instructions given by the router and thats all ...
if u stell need more help then contact me on yahoo jack_a00
There are now routers availabe in India that allow you to share your 3G or EVDO modem.A company out of Mumbai sells them called EK Wireless. I got one, a Hame HM433R portable unit and it rocks. Paid Rs 5499 for it. Certainly worth the money because its saved us a few times when the cable internet has gone down.
This should help you.
There is a free software called connectify , google it , which helps you share your internet connection.
It , unlike the mess ad hoc connection , provides a regular wlan wireless connection.
The software is new and has some glitches in it.
Another thing is that it works only on Windows 7 - which by the way is a very worthy product.
Mac users - have the internet sharing facility , in their OS.
Activate your wifi card in desktop / laptop
Connect to internet through EVDO
Go to network and sharing center > manage networks
Add a new WEP network and name it as mynetwork
set a 5 char long password
Click next and it will give you an option to share the internet conenction
Activate it and you are ready to go....
