Can I use Jio Fiber 4k box with ACT wifi connection?
  • Thread starter Thread starter srisri890
  • Replies Replies 6
  • Views Views 4,820
Andhrapradesh
ACT
I have jio fiber connection at the office (Rs.399 plan with Rs.1500 deposit). My plan is to pay the Rs.1000 difference, upgrade to Rs.2500 4k tv box scheme and then use the 4k box at my home just like Amazon firestick.
Is this possible? I don't have jio fiber connection at my home (service not available), currently using ACT broadband.
I already asked jio fiber installation engineer about this, he says their 4k box requires 150 mbps to start and so its not possible with ACT or any other wifi.
No Jio fiber locked with Jio ftth service only. Any other ISP, mobile net not work with this.
I tested Jio STB through my Railwire connection and everything worked fine. Although that may be because my 150Mbps plan is active and might not work after it expires.
I think you are an exception when it comes to this because it isn't that way for me and many others in this forum (maybe updates have changed something in recent times that I have not plugged in the STB for the absolute crap that it is)
I'll try using airtel4g or jio4g and update.
Can I connect jio router with Nokia router for extending WiFi coverage in my home. I got Nokia router with xstream fiber connection and I am planning to switch to jio fiber.
