Friends,
Hello to all members of this wonderful forum!
I got my Dataone connection last week (Home 500 plan). Am using Win XP on my PC.
The actual installation happened when i was away from home. So, i have a small doubt.
The modem/router allotted to me is a Starcom UT300R2U. I use an Ethernet-card based LAN connectivity mode. The technician who completed the installation has configured a 'dialer' based PPPoE connectivity setup - meaning, it is not an 'always-on' setup, but i have to physically click on the dialer icon (after switching on my comp and my modem/router), and then wait for it to establish connection.
Now, the problem is: i'm at times not able to establish connectivity at the first or second attempt, but it takes at least 5-6 attempts.
I know that i can at least try to resolve this problem to a certain extent by enabling the 'Always On' mode instead of 'Dial-up' mode. But when i try to open the modem/router config page (192.168.1.2 or 192.168.1.1), it simply doesn't open up!.
And yes, i am running Win XP, so there's no patching issue here(which is there for Win 98, ME users), and yes, by default, the suggested 'Obtain IP adress and DNS automatically' option is on.
So, I would like to know how i can reach my modem's configuration page, given the fact that my settings are as described, and i have tried to open it on multiple browsers, after clearing cookies and adopting all other standard procedures. Please also let me know your suggestions on how to change mode after reaching the modem page, and if that should solve my connectivity issue.
Would also like to know from all knowledgeable fellow-members which mode is best suited for use, dial-up ethernet or always on ethernet. I dont have a firewall, but i do have a good antivirus, and since i need to use a P2P program occasionally, i'm wary of using a firewall.
Thanks in advance!
Thanks in advance!
