Charging cable for Note 2
LordSpymaster
Airtel Xstream Fiber 200 Mbps Corporate Plan
Ex: Airtel vFiber 24 Mbps and Jiofiber 150 Mbps
So my stock cable went kaput. Then the cable i bought from Palika went kaput.
I wanna buy a cable specifically designed for charging phones, not for data transfer. It'll use the micro usb 2.0 port on the Note 2. Is there any cable which is made for charging?
My budget is maximum 500, and I'm willing to buy from sites outside India if the price is right.
Any suggestions?
Failing this, I'd like to buy the original cable that comes with Mid-High end Sony phones ie Xperia Z, cause I've used one and its very nice. Give me a stable 1500 mah.
xerxes said:
can this cable be called better than the one manufacturers provide?
Original cable provided by the manufacturer is too short and gives around 1500 mah. I am getting additional 300 mah using this new cable.
Also the look and feel of the cable is much better. Overall... a good buy.
AFAIK, its the phone that regulates the current drawn from the charger based on the battery charge. Now considering that the manufacturer would supply a good quality cable, I don't understand how another cable can give higher current than what the phone needs with a 3rd party cable?
Another thing is that Note II I guess doesn't have a Snapdragon chipset as per this page . So I guess it won't do any thing extra to my N4.
Can anyone throw some light?
Better than what Samshit provided?
Definitely!
Also the cable quality is good. So I'm guessing that it'll be a boon for any phone.
So get the 2m one when you need a long cable. It's easier to use the phone now that it has extra maneuverability while charging.
