Cherrinet - 200 Mbps - 2 TB - Chennai (Review)
  • Thread starter Thread starter warpspeed
  • Replies Replies 415
  • Views Views 139,746
Edit: No longer using the connection.
Cherrinet Fiber Broadband Review
Website: Cherrinet
Plans:
My Plan: Basic 200 Mbps (symmetric) 2 TB. It is prepaid and the rental is Rs. 1768 per month including taxes. They also offer 6 months+1 free and 12 months+2 free if you're looking for longer validity. Static IP is available at Rs. 5000 a year.
Got my connection up and running on the same day I paid. The fiber cable terminates at your premises on a ZTE ONU. Connection is reliable and the speeds are consistent.
Speedtest:
Singapore:
Netherlands:
NYC (USA):
DSL Reports:
Fast.com:
Torrent:
Browser download speed:
Steam (in Megabits):
Conclusion:
I'm very satisfied with my Cherrinet connection. I highly recommend them if you are thinking about getting a connection. I don't suggest going for the longer validity plans given they update them frequently. You won't be able to change it till the subscription ends. Also make sure they put you on Airtel Transit. My speeds were all over the place when I was on Tata.
Pros:
  • Great speeds.
  • Less Downtimes.
Cons:
  • Overhead cabling.
  • You don't have the option to change your plan till it's validity expires.
  • Their Tata transit sucks to the core.
Let me know in the comments if you want me to test anything.
Edit: Updated on 30/12/16
Edit 2 (12/02/17): Not a single downtime since my last edit. Added fast.com speedtest result.
Edit 3 (07/04/17): Didn't face any downtime since Vardah.
Edit 4 (04/05/17): Added DSLReport speedtest. Yet to face any downtime.
Edit 5 (19/08/17): Cherri upgraded my plan to unlimited and the connection is still going strong. Added updated plans.
Edit 6 (11/03/18): Faced two downtimes which were quickly resolved. Updated speed test results.
Edit 7 (04/05/18): They don't offer unlimited anymore.
Final Edit (28/05/19): Cancelled the connection.
@usrlocal ACT doesn't seem to throttle International speeds, if you're planning to go for it. Customer care, I guess is on par with Hathway which is below average.
@hemanathanvicky mr_grump5 said it better. If you predominantly use International servers then Hathway is the better choice.
@hemanathanvicky been using Cherrinet for past 3 months no downtime no speed problems with most of servers the only downside is that cherrinet have problems with some jio servers Jio vowifi,Jio cinema,Jio tv some Voot videos doesn't work.
I used to have cherrinet for the past 6 months and I can say the customer service and speed is the best (gonna try hathway soon).
The static ip is is as expected, with all ports unblocked.
Only thing is the static ip is too expensive and you need to upgrade to a SME plan to get it.
