Complete Automation For Dsl Nu!
  • Thread starter Thread starter chetan
  • Replies Replies 13
  • Views Views 2,873
dittoeven i disconnect my pc at 7:55 n shutdown at 7:56till nown nuttin happened to ne d/li mainly use bicometn the reason s since ur disconnected so der is not d/l goin on n than pc shuts down
Hi Guys,Ok so there is no problem with corruption of downloads if you close the client without pausing but you definitely lose sources if you don’t pause your downloads so the next time you start downloading it will take slightly longer for your download to start…You don’t have to worry about this if you are downloading a popular file but if it’s a file with limited sources then pausing your downloads might help and I don’t mind a advantage however small it may be and it doesn’t require too much effort to pause the downloads so I don’t see the reason why it’s a big issue…I have been in a position when I have downloaded huge files with a speed of only 5 KB/s for a week only to find that they are corrupt but this was before verified files and advanced file hashing systems were in place but I still fear those experiences and it has become a habit to check reviews and pause before exit etc…Better safe than sorry is what I firmly believe in…Cheers…
i donot think that if we donot pause than we loose some sources.i get constant speed after 5-6 min on most off the torrent n torrent being the major share of night d/l.n never noticeed that i hav lost some sources
losing sources may have been a problem b4.. but not anymore. even if your downloading from only a couple of sources! last few days i have downloads 6 torrents which had no m0ore then 3 peers! and didnt have any problem of losing sources or data loss when my comp shut down automatically..
