jackscs2005
Hi,I have BSNL UTStarcom WA3002G4 ADSL Router. Recently i shifted to new location and BSNL has not yet trasferred my connection to new place even though new place is just the next row from old place. After following for more then a month i cancelled the connection and moved to ACT broadband. BSNL Suckssssssssssss.I am very happy with the speed at the same cost (even lesser) then BSNL and any other provider.Now problem is, ACT technician told me that i can't use BSNL WA3002G4 router with ACT connection. I need to buy another router and that cost me another 1500-2000 /- RsNow my query - "Is there a way to use UTStarcom WA3002G4 router with ACT broadband connection?".If yes please provide steps to do so. Also i am not sure if ADSL router WA3002G4 can really be used with ACT broadband lines.UTStarcom WA3002G4 model comes with following ports. 1 Port for telephone input line, 4 Ports for LAN connection, 1 Wifi antenaIf we can convert this router to a switch then our problem will be solved but the question is how to do that. I dont know how to configure WA3002G4 router to work as switch.regards,Jack
