Hi,
Last year I bought a beetel 450TC1 router without knowing it doesn't work with BSNL connection - I wish I had checked this forum then.
I have tried long & hard to make it work but no luck . Gave it up when the BSNL technician told me "this is only for airtel, will not work", issed-off: :depressed:
Now doing one last try before I spend another 2k on a new router. Can you guys pls help me, if its possible, to make it work?
I have looked at all the old posts here, they all deal with getting the wifi working & mention that I need to downgrade the firmware, but for me even LAN does not work.....
Is there any hope at all?
So far I followed instructions in these 2 links
techline
pradeep nayak
with no luck! No internet with LAN also. I would be eternally grateful if some one can rescue me from this situation with detailed instructions and also share the firmware needed.
Just as FYI: interms of networking/hardware I am pretty much a newbie.
Pls help
:Thank You:
techline
pradeep nayak
Pls help
:Thank You:
