@ChakdepatFew things to note:1.
Laptop is a mobile device, and there is a thrill of using it while you are sitting on your verandah, with a cup of coffee and browsing it withotu any wires. For this you need a Wi-Fi
Router, and I can suggest an ideal router , which is not at all heavy on pocket and gives good performance is
Netgear WGR614v6.For configuration, search this forum. There are godo number of explanations for the same.2. If you have more than one Ethernet prots, then you need to buy a RJ45 cable.Plugin and configure the way you configured the desktop TCP/IP settings. Better to have
ADSL Modem in PPPoE mode, so that you don't require dialers to connect.3. Pehaps you will surely have a USB Port in the ADSL Modem. So install drivers in Laptop, and configure connect USB cable. Then configure laptop, as you wud have configured your desktop TCP/IP properties.Let the forum know, if you have any issues.Chow,J a c k
