use PPPoE mode inside the DNA-A211-I to connect to Internet then you have Internet everywhere.
to do that login to your modem & put these settings
PVC Number – PVC 0
Connection Type – PPPoE
VPI/VCI – 0 / 35
User Name –
Password –
Thank you for your response.
Yes I did above but still just connecting to the wifi is not helping. Even when I am using
Laptop, just connecting to wifi is not giving me internet access. I have to click on dia;up icon to enter username and password to connect to internet.
Device Info
Board ID: 96338W-20P2
Software Version: 3.08.02.IB.02.01_1701_022709
Bootloader (CFE) Version: 1.0.37-10.1
Firmware Version: DNA-A211-I-0001.01
Hardware Version: DNA-A211-I 2.6
Model Name: DNA-A211-I
Wireless Driver Version: 3.131.35.6.cpe2.0a.s
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 509
Line Rate - Downstream (Kbps): 2045
LAN IP Address: 192.168.1.1
Default Gateway:
Primary
DNS Server: 192.168.1.1
Secondary DNS Server: 192.168.1.1
ATM PVC Configuration
This screen allows you to configure an ATM PVC identifier (VPI and VCI) and select a service category. Otherwise choose an existing interface by selecting the checkbox to enable it.
VPI: [0-255] 0
VCI: [32-65535] 35
Enable VLAN Tagging
Service Category: UBR Without PCR
Enable Quality Of Service
Connection Type
Select the type of network protocol for IP over Ethernet as WAN interface
PPP over ATM (PPPoA)
PPP over Ethernet (PPPoE)
MAC Encapsulation Routing (MER)
IP over ATM (IPoA)
Bridging
Encapsulation Mode
LLC/SNAP-BRIDGING VC/MUX
In the next screen I have netered my broadband user name and password.
Bridge PPPoE Frames Between WAN and Local Ports (Default Enabled) option is checked.
Summary:
WAN Setup - Summary
Make sure that the settings below match the settings provided by your ISP.
VPI / VCI: 0 / 35
Connection Type: PPPoE
Service Name: pppoe_0_35
IP Address: Automatically Assigned
Service State: Enabled
NAT: Enabled
Firewall: Enabled
IGMP Multicast: Disabled
Quality Of Service: Enabled
In LAN Set up:
Enable DHCP Server is checked.
Is there anything else I am missing.
