CONNECTION PROBLEMS + Reconnecting in Bridged Mode changes latency ? WHY ?
  • Thread starter Thread starter rsen
  • Replies Replies 4
  • Views Views 1,325
rsen
Regular
Bsnl
1st off - horrible latency fluctuations at random times during the day, slow speeds, sites not opening, torrent speeds awful, download/upload clogging/choking connection at these times, peak hour internet unusable, 2-8am period mostly unusable, 7am-8am 300-400ms above normal, packet loss, outages.
what's going on ?
underwater cable break ?
bsnl server monkey died inside a router ?
Why does disconnecting and reconnecting the BSNL BB connection affect latency so much ?
Same dns server, no other change, but latencies change every time i reconnect.
Does reconnecting choose a different routing path ?
Also; is anyone else finding random congestion/high latency/pings/packet loss at random times during the day ?
I'm getting 500ms right now and it's 5pm - hardly peak time anywhere.
What's going on ?
I called BSNL BB and the call center people are clueless about this issue.
Here's a screenshot showing how reconnecting affects latencies - the window on the left is to a US server and the window on the right is to an Australian server.
http://img294.imageshack.us/i/weirdlatency1.jpg/
Uploaded with http://imageshack.us
http://img687.imageshack.us/i/weirdlatency2.jpg/
Next up : huge amount of connection choking at the slightest connection bandwidth usage - i just tried to upload the images above and my connection gets horribly choked - latencies shoot up to 500-600ms above normal (when this continues you see packet losses)
pings to a US server during upload to imageshack :
Code:
Reply from 63.241.193.18: bytes=32 time=437ms TTL=244Reply from 63.241.193.18: bytes=32 time=437ms TTL=244Reply from 63.241.193.18: bytes=32 time=437ms TTL=244Reply from 63.241.193.18: bytes=32 time=437ms TTL=244Reply from 63.241.193.18: bytes=32 time=437ms TTL=244Reply from 63.241.193.18: bytes=32 time=421ms TTL=244Reply from 63.241.193.18: bytes=32 time=515ms TTL=244Reply from 63.241.193.18: bytes=32 time=687ms TTL=244Reply from 63.241.193.18: bytes=32 time=1172ms TTL=244Reply from 63.241.193.18: bytes=32 time=1999ms TTL=244Reply from 63.241.193.18: bytes=32 time=2312ms TTL=244Reply from 63.241.193.18: bytes=32 time=2077ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=468ms TTL=244Reply from 63.241.193.18: bytes=32 time=468ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=500ms TTL=244Reply from 63.241.193.18: bytes=32 time=500ms TTL=244Reply from 63.241.193.18: bytes=32 time=499ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244Reply from 63.241.193.18: bytes=32 time=500ms TTL=244Reply from 63.241.193.18: bytes=32 time=484ms TTL=244
pings to a Australian server during upload to imageshack :
Code:
Reply from 202.6.141.219: bytes=32 time=452ms TTL=51Reply from 202.6.141.219: bytes=32 time=452ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=452ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=436ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=624ms TTL=51Reply from 202.6.141.219: bytes=32 time=953ms TTL=51Reply from 202.6.141.219: bytes=32 time=1625ms TTL=51Reply from 202.6.141.219: bytes=32 time=2281ms TTL=51Reply from 202.6.141.219: bytes=32 time=2468ms TTL=51Reply from 202.6.141.219: bytes=32 time=640ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=437ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=452ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=437ms TTL=51Reply from 202.6.141.219: bytes=32 time=453ms TTL=51Reply from 202.6.141.219: bytes=32 time=452ms TTL=51Reply from 202.6.141.219: bytes=32 time=452ms TTL=51
traceroute to cnet.com (a server in west coast USA) -
Code:
C:\>tracert www.cnet.comTracing route to gtm-rb-tron-xw.cnet-basic-performance.akadns.net [216.239.122.164]over a maximum of 30 hops:  1    12 ms    13 ms    12 ms  59.93.192.1  2    46 ms    47 ms    47 ms  218.248.255.86  3   173 ms   169 ms   169 ms  121.244.68.57.static-lvsb.vsnl.net.in[121.244.68.57]  4   178 ms   177 ms   173 ms  203.197.33.130.static.vsnl.net.in [203.197.33.130]  5   392 ms   394 ms   391 ms  59.163.16.134.static.vsnl.net.in [59.163.16.134]  6   389 ms   402 ms   402 ms  if-11-0-7.mcore4.PDI-PaloAlto.as6453.net [207.45.213.153]  7   411 ms     *      554 ms  if-3-0-0.mcore5.LAA-LosAngeles.as6453.net [216.6.86.10]  8   419 ms   413 ms   413 ms  Vlan1147.icore2.LAA-LosAngeles.as6453.net [216.6.12.21]  9   412 ms   412 ms   412 ms  192.205.35.129 10   521 ms   517 ms   512 ms  cr2.la2ca.ip.att.net [12.122.129.30] 11   523 ms   516 ms   519 ms  cr2.dlstx.ip.att.net [12.122.28.177] 12   518 ms   522 ms   522 ms  gar10.dlstx.ip.att.net [12.122.138.121] 13   521 ms   505 ms   501 ms  12.87.121.22 14   511 ms   518 ms   521 ms  c18-rb-gtm1-tron-xw-lb.cnet.com [216.239.122.164]Trace complete.C:\>
before anyone asks :
1) splitter is fine, same issue if i connect directly
2) line is fine, had lineman check and replace wires last month
3) changes dns servers is useless (+/- 10ms difference when i do)
4) no virus/trojan etc
5) modem is brand new (getting same problem with old bsnl modem)
6) problem happens at different times during the day.
PLEASE ADVISE
I AM FED UP WITH BSNL
IS THERE ANY WAY TO FIX THIS BULLSHIT
anyone good with networking that can help me/explain this pls :D
[p.s. sorry for making this same post on 2 forums]
o wow :(my hopes of getting this fixed by switching ISPs just vanished :/i booked a reliance 749 combo plan (no fup, seemed pretty good)i wonder if they are having issues too.anyway thanks for your response.
airtel broadband is doing the same at my end right now.
I thought Airtel is a very good ISP. Unfortunately they do not have service in my area. :(
well airtel is no longer a preferred internet service provider. their new packages are shitty in nature for folks like us.
