Custom Web Interface for Nokia G-2425G-A
  • Thread starter Thread starter albonycal
  • Replies Replies 26
  • Views Views 6,141
Nagpur
AS24560 (Airtel)
Mikrotik hAP ax^2 Router
Hey, I am currently making a custom web interface for the Nokia G-2425G-A ONT.
It uses ssh in the backed and makes changes using the cfgcli built in the nokia firmware or custom scripts.
It will only work for unlocked ONTs.
I am adding a button which would configure ULA. Because the ONT by default doesn't announce a ULA prefix.
The Temperature monitor updates every 5s
and I am in the process of adding a live bandwidth monitor.
Any feature requests or help will be appreciated.
I will opensource this once it's in a good enough state.
Thanks
(It currently looks like this: )
Showing optical power , uptime ?
Update: Added Optical Power and Uptime
And I have made it "API Like" so you could create custom scripts easily.
For ex. it gets the optical power from /optical endpoint
What else should I add ?
Maybe the FTP/SFTP controls? That is, unless you're aiming for a dashboard/monitoring system.
I am aiming for a bit of both tbh, and personally I think you shouldn't be using ftp and that too the outdated binaries which are included with embedded devices
