Hello Friends,
This is Akash Patil, from kalyan. All kalyan users are hereby informed that they can use DC++ ie HUB.
some Ulhasnagar, Badlapur, Shahad n dombivli users can aslo connect to this hub.
HUB NAME :- ¨‘°º©º•MاT WÅÑT€Ð•º®º°‘¨
Hub Address :- 10.46.106.91 or 10.46.106.91:12100 or 10.46.106.91:8080 or 10.46.106.91:55555
Minimum Share Limit :- 30 Gb
For Connecting this hub all u need 2 do is change urs ips according to following ip ranges.
For Kalyan n Badlapur users :
10.40.98.xxx (Recommended For Kalyan users )
10.40.99.xxx
10.46.100.xxx
10.46.101.xxx
10.46.102.xxx
10.46.103.xxx
10.46.104.xxx
10.46.106.xxx
10.46.108.xxx
For Ulhasnagar Users:
10.40.104.xxx
10.40.105.xxx
10.40.108.xxx
For Dombivli Users :
10.46.98.xxx
10.46.99.xxx
10.40.100.xxx
10.40.101.xxx
10.40.102.xxx
10.40.104.xxx
10.40.106.xxx
For Shahad Users :
10.6.102.xxx
10.6.103.xxx
If u dont know how to change ip then go to LAn properties > Internet Protocol(IP/TCP) click on properties.
Select use the following ip Address.
in that put Above ip.
For eg:
IP Address : 10.40.98.xxx
Subnet
Mask : 255.255.255.0
Default Getway : 10.40.98.1
You can also connect 2 other hub in network.Hub address of those hubs are as follows
W‡ZÁRЧ H‡ÐÊØÚT™ 10.46.98.105:11211
HÜßLÃÑÐ 10.46.103.84:11211
ÐÃRKÑ€XU§™ 10.40.98.105:11211
««•ÐÊV‡£§ † ¥ÁRЧ•»»™ 10.46.104.9:12100
LiGhTnEsS 10.46.100.133 or 10.46.100.133:12100
Note : use above ip ranges as per your location, n while connecting your NET has to b Disabled bcoz its LAN hub.
If You have n e pr0b in connecting HUB then email me:
E-Mail Id :
[email protected]
[email protected]
[email protected]
[email protected]
Enjoy ,
